When factory data reset loads your previous ROM..
Is this a bad thing? First time I've ever played with root and I guess I should have read up abit more about it :D
Any suggestions?
Details = Followed instructions from a Youtube video, and got a CyanogenMod. Pretty cool and all, but wanted to try another. Used the same method described in the youtube video to get this Fresh rom i keep hearing good reports about. Liked it, but now wanted to do a factory reset, and it goes back to the previous, CyanogenMod.
Thanks
Link to youtube video: YouTube - The EASIEST way to root an Android and add Recovery Image
Are you doing the factory reset from the recovery screen? You should wipe the factory/data, the davlik cache and sd:ext (from the recovery screen) each time you flash a new ROM unless the developer tells you otherwise.
Yes I tried that a few times, and it still comes up with the previous Rom. I didnt know all that.. Any way you know of that i can get the initial previously installed Android 2.1 back on the device like its brand new?
Are you flashing a NEW ROM after wiping everything?
If you really wanted to get back to stock (unrooted and all) you could run the RUU.
That's exactly whats happening, kinda like I overwrote my nandroid backup files with that rom.
I do want to get back to stock, ill find the correct RUU and see what happens from there.
