When I try to flash via fastboot system.img to YU Yuphoria I get the FAILED (remote: flash write
atulsam
C:\Users\SAM\Desktop\New folder\Yu_Yuphoria_YU5010_V2_V2_12.10.12\Firmware>fastboot -i 0x2A96 flash system system.img
target reported max download size of 268435456 bytes
erasing 'system'...
OKAY [ 0.018s]
sending sparse 'system' 1/4 (261218 KB)...
OKAY [ 8.737s]
writing 'system' 1/4...
***FAILED (remote: flash write failure)***
finished. total time: 9.167s
Is your bootloader unlocked?
I've seen that write failure (or similar) for three different circumstances:
1. Locked bootloader
2. Hardware issue (normal failure due to long-term use)
3. Hardware issue (known failure due to water exposure--although the write failures were (are) intermittent)
Your output does seem to indicate a partial write (flash) operation started to work, but that's not conclusive.
If your bootloader is unlocked (verify with fastboot getvar unlocked command, should output "unlocked: yes" if unlocked), then other than retrying the flashing operation, not sure what to tell you...:(
If your bootloader is locked, then you'll obviously have to unlock it first, eh? :)
Thanks for your reply,
I executed fastboot -i 0x2A96 oem unlock before flashing.
I also checked fastboot getvar unlocked so result is following
unlocked:
finished. total time: 0.002s
And one more thing when I flashed cache , userdata , recovery , boot. It is all fine, there is no error.
But this error occurs only when i tried to flash system.
My Phone was stopped working due some decryption error and internal memory is showing as 0Mb in TWRP.
I had followed my threads but no luck.
Can you post the output from a fastboot getvar all command? (and/or fastboot -i 0x2A96 getvar all)
It's still not clear that your bootloader is actually unlocked given the output that you got from the fastboot getvar unlocked command...you might also need the "-i 0x2A96" USB vendor id option that you used for the unlock command you posted above.
I don't think it's unusual that you're seeing failures on the system flash operation since that transfers the most data since it's a larger partition.
Thanks @atulsam--that was perfect!
Unfortunately, I've seen that (the write/flash errors on /system) before on several Nexus 7 tables (both 2012 and 2013 versions) without any obvious fix :(.
I've also see it on a Nexus 5 that experienced water damage, but that problem has been intermittent and I've been able to try multiple times and eventually get it to flash--but knowing it's got a problem, I'm not surprised when I encounter issues.
Is this an older device perhaps that's finally seeing hardware issues? :confused:
This device is from july 2015, so i can say that not too much old. It does not seems to be hardware issue because boot, recovery, cache , userdata is flashing successfully. But only problem occurs in system.
Have you gone through the image which i posted earlier. Have you found something unusual.
Well, eMMC memory errors or failures can happen anywhere and just because one operation is successful (like the cache flashing of only 5MB of data) doesn't mean that you won't or couldn't see that error in another place.
You're also trying to flash 255MB of data for your 'system' flashing operation--a much larger amount that encompasses more area and possibilities to encounter a bad area of memory.
The "FAILED" message is pretty clear: "flash write failure", so it's either a still locked bootloader issue or a hardware issue from my standpoint and understanding...:(
See this output
>>fastboot oem device-info
(bootloader) Device tampered: false
(bootloader) Device unlocked: true
(bootloader) Charger screen enabled: true
(bootloader) Display panel:
OKAY [ 0.007s]
finished. total time: 0.007s
I think the device is unlocked.
Anyway thanks to you. I am still looking for the solution. If I got the solution I'll get back to you.
I've run across this as well on other devices. Seems to be a fastboot limitation due to the large size of system on some devices as @scary alien mentioned already. Make sure you're updated to the most recent fastboot binary as older ones have this problem way more frequently. If you're not up to date, that's step one, then retry.
If you're on the newest and it still doesn't work, I'd recommend rooting if you're not already, get your partition table or better yet, locate your path to the system partition in the format of dev/block/xxx/xxx/by-name and then use the dd utility to write system via adb root shell. It seems to power through large write functions better than fastboot. I've had success using that method in lieu of a fastboot when incurring the same error as yourself.
Granted that I'm new to fastboot devices, I have been learning/ flashing a few Motorola devices.
Found and have been using mfastboot. Supposedly mfastboot will flash much larger system files than standard fastboot.
Not sure if this is the problem but couldn't hurt to try.
Thanks for your advice. Actually, my system file size is approximately 1 Gb. So think this error is due to max size . and the max size of fastboot 256 MB . can you pls tell me how to increase max size of fastboot.
What makes you think that the max (file?) size for fastboot is 256 MB?
I read some threads where it was mentioned that by default max size is 256 MB to flash. But my system image is around 1GB so maybe that's why am getting the error. Can you suggest another method to flash system.img file.
when i execute this command.
>fastboot -S 1024M flash system system.img
erasing 'system'...
OKAY [ 0.848s]
sending 'system' (1027359 KB)...
FAILED (remote: data too large)
finished. total time: 1.608s
This data too large error is showing. So what may be the problem.
Thanks for your suggestion. I also tried mfastboot but no luck. My system.img is 1GB in size.
erasing 'system'...
OKAY [ 0.848s]
Ah, I have seen that one before (and I don't think you had mentioned a size issue w/regard to that message)...
I did (finally!) find a version of the fastboot source that actually contains that error "FAILED (remote: data too large)" message:
and found a site that suggests download the latest version of fastboot.exe from the Android SDK, which I've done and attached to this post (it's inside the .zip file since we can't post .exe files directly here)
The size of the system.img file that you posted in the first post was 261218 KB, so perhaps you should be specifying the "-S 2048M" size option/argument to fastboot instead of "-S 1028M"?
Try both that and the new fastboot that I've attached and let us know.
Cheers!
@atulsam, just revisiting this real quick:
A "fastboot getvar all" or "fastboot getvar max-download-size" should reveal the maximum size that your device can handle in a given transfer.
My advice above to try a larger value appears to be opposite of what you'd actually want to do--trying a smaller size should give fastboot more of a chance to transfer the file in palatable chunks, so trying a size like fastboot -S 512M flash system system.img would have more of a chance of being successful.
@manthanshah16, see if thise helps you, too.
Cheers!
@atulsam @scary alien I am also experiencing the same issue on my YUPHORIA 5010 device. TWRP 3.0.2.0 is loaded on the device and that shows 0 MB internal storage. Unable to mount system, data, cache partitions....says invalid arguments. No fastboot mode. My understanding is when there is no internal memory or the system partition detected, where would it flash the system.img file. Is there a utility that we could use to recover the internal memory first? If we can get to mount the partitions, the default commands will flash the system.img as well.
Please help.
Welcome to AF, @samujjwal kashyap -- sorry to hear you're also have similar issues to the guys above...:(
I'm not sure what else or more I can add, since I don't actually have this device--I was just chiming-in with some generic fastboot information that I thought might be helpful.
Hopefully one of the others will reply back! :)
Please help.
I didn't find any solution, Service center replaced motherboard. They said it is hardware issue.
