jericko
I am running CM 2.6.0.1
When I try and clear my Dalvik I always get the following error:
E:Can't Mount /Dev/block/mmcblk0p2 (file Exists)
It does not prevent me from Installing Roms.
So I was able to get this fixed, but not sure why:
So I took out my SD card and out in a temp new one (same size) and it did the same thing when I tried to clear Davlik cache (same error)
So then I went to "Partition SD Card" and choose 128 (smallest Option) then 0M for swap. Once I did that, I do not get that error when I try and clear Dalvik. I took the SD card out and put it in my PC and I now see a 128M partition that looks empty. Put my Original SD card back in and without the partition, I get the Dalvik error.
Do I need this partition and for what?
Thanks guys, sorry to sound like a newb.
-Jason
-Jason
