Hi i have searched and found similar issues on other handsets but cannot find a thread and suggested solutions on the new S2.
I have only owned it less than two weeks and noticed when swyping or typing that if i have to correct a word once in awhile and use the delete button to move back ...either partially or fully to fix a word...
...i will start to type or swype again..happens either way..that at random the cursor...
..will drop down to the line that says "sent from samsung mobile" and in the middle of that sentence will move the cursor there and start typing inside the middle of that sentence.
If i purposely go back up to where i left off and tap to place cursor there...it will put the cursor back up...and as i begin to correct word or continue typing or swyping again...it will...you guessed it....immediately move you back down past the empty space to middle of tagline again and again and again. then randomly work for a bit..then do it again. Almost in every email at some point.
i know of no other way to describe it, happens randomly but enough that i want to pull my hair out. I cannot simply reply or compose an email and swype away, i have to look down as many times, most times, it will have my paragraph half done and in middle of the bottom tag it will have my typing down there.
anyhow heard of this problem on S2 and suggestion? please!
