pancho32392
Where can i get a full functionality of beats audio
which one do i click on?
Virgin Mobile ICS (Bottom one)
Also the Beats Audio one
I flash it already and it doesn't work
Can someone tell me what beats audio is?? I am s-off with midnights latest rom, 1.2. If I choose to flash this, will it work on midnights rom. Also, over at the xda thread mentioned here, there is also a file for the camera. Can anyone tell me if they have flashed this file for their camera and also if this was already included in midnights latest rom update.
Thanks
Back when I could actually enable Beats in PowerAmp, it definitely added more boom to my mids and everything else in general without drowning out the higher frequencies.
I miss it tbh![]()
Beats audio is just an EQ setting; not even a BBE effect. It does not improve the SQ of your phone.
Waste of time.
Mobster Rom V has Beats in Poweramp
You clearly have no knowledge of how audio effects work.
Beats audio is nothing but a system-wide EQ setting. Not a BBE effect. An EQ setting, which can be accurately reproduced by any other setting. I prefer my signal to be clean.
IMO all that really matters is whether the Audio Sound Better, Clearer, and preferably Louder
Myself, and several members of Head-fi have been able to accurately reproduce the EQ settings that beats audio applies. If it were a BBE effect, this wouldn't be possible.
Worthless. This doesn't improve SQ.
You can get better results with any decent user configurable eq. Beats basically does that same thing a loudness setting does on any stereo: increase bass and treble. On my headphones it actually makes the bass worse as mine produce very solid bass already.
I am sure if was paired with the right Beats headphones it would help. My number one problem with iPhone is no user configurable eq.
