Help Where do I set words for voice command?
Ok that got me to the wake up command but I want to control the camera. I didn't see anything in there for that
Once you enabled voice commands for camera, go to your camera app, and under the settings, you should see the option to enable voice control (camera--settings--in the popup window, go to settings tab--scroll down--click on voice control - enable)
I re-read your op - I don't think you can change the words for the voice command, but you should be able to enable voice command for camera this way
