Help where does a downloaded file go? (droid x)
sx4dude2013
Android Expert
i went to open a pdf file and it started to download,,where is it located when its done? and is it normal for the x to heat up under heavy use?
its in your sd card, the folder is called downloads.
i have not experienced the heat yet. but i will be down in south beach in november;)
youre running a slim phone packed to the max with functions and high caliber hardware. yes its normal for it to become warm.
Get an app called astro. Its a file explorer and it will allow u to see and edit files on your phone. It will be under the sd card. If u have any questions lmk
