Help Where does the battery go
leftystrat
My coworkers are experiencing all sorts of difficulties with their Ones. I like mine.
The other day I charged my phone by 3pm. By 11pm, it was in the yellow. This was odd.
I checked on what used the battery and there was nothing out of line. BT, GPS, wifi, and almost everything else is off. No social networking, location, not even a phone call. A few text messages at most.
The next day I recharged and it lasted the whole weekend. Same config, almost no usage.
I rebooted on general principles.
Why is battery usage so seemingly random? This isn't the first time.
Sounds like you weren't getting a full charge even though it said you were. I think this issue is called "battery memory". Always try to recharge fully, if you're having issues often then charge the phone to 100% with it turned off, then unplug and use it for 30 minutes, then charge the phone to 100% with it turned off, then unplug and use it for 30 minutes, charge the phone to 100% with it turned off. Now it should be recalibrated.
