Root Where in battery usage would LWP Show?
Needsdecaf
Android Expert
When hitting battery usage, would the LWP show up under display?
I loaded in a new LWP from the market and checked battery usage and display was off the chart % wise compared to my normal use. And that was with some pretty decent phone activity.
I disabled the LWP to check, but does anyone know if it will show here? Or anywhere?
Thanks all!
My phone has been charging, but I believe it gets its own category. I think I remember seeing it listed one. It was a single digit number though.
