I have that widget but it just gives a single % number. I was referring to the built in "Battery Usage" that shows the breakdown by different functions ie. % display, % radio, % wifi, % standby, etcWell if you just download battery widget from the market, you could follow how decent it is once you condition the battery.
Tmobile MyTouch 3g has it and that on 1.5 I believe.I believe that's a feature of Android OS 2.0 and not in 1.5.
That does makes sense. I thought the mytouch had 1.5 when I had it but maybe it was actually 1.6 because it definitely had the battery usage meter. It's too bad this device does not because it would surely shed some light on what's killing the battery.Actually I think it might have been added into 1.6, which is why the MyTouch 3G has it (it got the Donut update a little while back). Not positive on that though, but makes sense.
