Help Where is clip viewer
  • Start date Start date
You can't generally view the clipboard. The last think cut or copied will remain in the clipboard until something else is copied or the device is restarted.
You can simply longpress in any field that you can type in (email, text message, notepad, this thread, etc.) And select paste. That should paste the contents of whatever is currently stored in the clipboard.
