Root Where to find apex for gb?
you need to PM Fabolous and ask him for a link to it
if you have twitter you can search through his feeds
cause as of right now he doesnt want apex for gb to be released publicly yet
If I install apex 2.0 alpha 2, can I restore data from liberty 2.0.1 or will that screw everything up?
i have flashed from gb back to froyo with no problems, but i have heard others have had a problem, so im not so sure.
What if I just want my data? Not restoring the whole backup, just advanced restore data?
EDIT: Well I tried it, didnt work. Started bootin up with the liberty boot animation and it was flickering all whacky. I just wiped data in stock recovery and all is good, guess I'll just have to start over. So much for my Paradise Island game...
thats what titanium backup is for bud. it saves the data, doesnt matter which rom you are on, whether it be froyo or gb
I thought titanium backup only saved the apps? Not the data with them. Everytime I restore apps with titanium backup, I lose all progress/settings that comes along with them. I must be missing something in TB... any ideas?
I always use the Batch option and "back up all user apps" and then "restore all apps with data". It always restores the app settings and game progress for me.
it saves apps and data, i have restored fruit ninja multiple times, as well as the moron test and i only restore data cause the app reinstalls itself
just do a backup of something, and when you go to restore it, it asks do you want to restore the app only, data only, or app and data only
I don't get that option when I click restore, it just says takes me to install the app. Ill try uninstalling TB and reinstallling it.
EDIT: After reinstalling I do get that option. I wonder why the hell I didn't before. Anyway, thanks for your help!
