I have older version of cwm can you pm me the link too for the newer one and any directions of any lines that I have to modify ? BY the way do you hear of any problems with the older version ? I havent used it too much seems ok.
Sent you msg.
For anybody else getting main old version error,open text file in the zip and change main version to 2.12.651.5 ,should update fine after that![]()
I know I found that post also a while back also, I'm playing with my phone now... where is the current "main version" I don't see it anywhere... like for future reference?
Use 7zip to open 5.0.2.8 AS YOU LAY IT OVER 5.0.2.7, this is how I updated CWM on my rooted Design! Hope this helps![]()
