Check Amazon. All sorts of them.
Just got a RAVpower battery that seems to be peforming well.
Amazon.com: RAVPower
I've been looking for a good battery also. I can't seem to find one. Amazon has many batteries, but after reading some of the reviews, it seems you never know what you might get.
if you gotta buy a battery i would go with the zerolemon its a bigger battery but will last you two - four days depending on how much u use your phone this battery is also sold on amazon.
Amazon.com: [180 days warranty] ZeroLemon Samsung Galaxy S III 7000mAh Extended Battery + Free Black Extended TPU Full Edge Protection Case(Compatible with Samsung Galaxy S III GT-i9300, AT&T Samsung Galaxy S3 Samsung i747, Verizon Samsung Galaxy S3
:thumbup:I purchased a battery by Onite for my Samsung Transform Ultra. My son is still using it and it's over 2 years old now. The original Samsung battery died after it was just over a year old. I'd gladly purchase one of their batteries again vs OEM.
Have you tried the Onite for the GS3?
+1 on that Zerolemon battery bro. It may add a little extra weight but it's all worth it IMO. Zerolemon also makes a rugged case for the phone. It is made for the 7000mAh battery but can also be used with a stock battery. Its very nice being able to use my phone the way I want to. Whether it be listening to music, taking pictures, surfing the Internet, or playing games. That Zerolemon battery gives me the freedom to do so.:thumbup:
Do you have any issues taking pictures with that case? (the eyelet? for the camera is kinda deep and I thought that might cause a problem)
I am thinking about getting that battery and case and maybe using my GS3 for another 18-24 months or so. The larger screens on the S4/S5 or Note are nice...but I'm thinking if my GS3 had a 7000mAh battery and KitKat (w/root of course) then I don't really NEED an upgraded phone.
I've got the zl for my older s3, the only problems with it is nfc is hit and miss sometimes. Camera is definitely not affected.
Thanks alot! I know what I'm ordering up for Fathers Day.![]()
