Where to Get a Spare Battery?
6 hrs with moderate usage. 8-9 hrs just sitting in standby. (BTW this is between charges and not having to plug it in at work.)
Then you have some problem with the phone not sleeping or some app waking it up.
Install the spare parts app and check what is using your phone under partial wake usage.
So after removing all on screen widgets as well as task killer and replacing it with advanced task manager I am finally getting th 2 days between charges you guys are referring to.
You mean you had Task Killer widget? Or you only used the app? It's just that the app itself is quite harmless.
I was just using the app and separate widgets but in an other forum someone mentioned that task killer kept the phone from sleeping or something so I tried removing it and all of a sudden i'm getting proper battery life... don't know how or why but I'm just happy
Yup the taskiller and battery widgets were big battery drainers for me. I easily get 2 days now, usually 3 or more. I don't have any apps or widgets auto updating (twitter/facebook, weather etc. etc.)
