Help wheres my memory go? few other questions..
7808
Member
i have a couple month old sprint hero with the sprint software/firmware that comes on it and a couple questions
when i open advanced task killer after powering up my phone, even though there is a bunch of crap running i still have like 50-70k memory available, i kill unused/junk apps like sprint zone, IM, gps etc.. then i only have the basics going and its closer to 80k, hours later same couple apps running i will have like 30k memory and the phone seems slow. anyone?
any way to get rid of the lag on the actual phone part of the phone ?(dailing, ending calls etc..)
is there anyway to change what programs start with the phone? i see where it says run at startup or whatever in manage apps but i cant change it, i hate that sprint zone, gps, IM, and whatever always starts with the phone. id like to just remove sprint zone and all nascar/NFL/ sports crap but i havent had time to figure out how
I know sprint told you to use a taskkiller, but it is unnecessary. Android will take care of itself, as long as you back out of apps and don't just press the home button. This link will help you understand why...
http://androidforums.com/sprint-htc-hero/26997-task-managers-your-hero.html?highlight=taskiller
The only sure way to get rid of lag is to root your phone and load a custom rom. Other fixes work for some people, but rooting is pretty much guaranteed to help. Here is a rooting thread for you...
http://androidforums.com/sprint-her...g-guide-updated-7-10pm-est-aug-30-2010-a.html
thanks, guess its time to root. will i still have voicemail download to my phone with rooted phone? really the only thing i care about that came on it, that and the gps and google voice search is nice.
Yes, you will have vm. Depending on which rom you choose, you may have to flash a vm app, but many roms are complete with vm right out of the gate. Good luck, and if you need help let us know!
