Swiping left activated vibrate mode now.you should be able to turn it to silent from the lock screen by swiping left, by holding down the power button, or placing a widget on your homescreen.
what about the other 2 suggestionsSwiping left activated vibrate mode now.
(not even a glitch, the icon changed as well to indicate a vibrate)
I currently use quick profiles, so it was more something I noticed than something I was having issues with. But I checked the power buttone one and that still is there.what about the other 2 suggestions
In settings under sound change the vibrate option.
And none of those settings are the same as how it used to be.
The conclusion is they removed that option, with no replacement.
Settings> Sound> Vibrate, with four possible options.
-- Hasnt seen the link Johnlgalt posted, to do what TC is asking setting should be Never or when not in silent mode.
