Which apps are compatible with SD card installation?I
ifb-online
Is there a list apps that will load or relocate to SD card space after Froyo 2.2 has been installed?
I have had had a look through my apps and have yet to come across one that will :(
Ian
Is there a list or should we compose our own?
GPS Status
That's the only one I know that can. Good little compass, and GPS pos app...
however to my recent experience almost all apps can be moved to SD if workaround is used that was described in different post
