Which Bluetooth earpiece works best with voice command
kdiver58
I currently have a Plantronics M55 bluetooth earpiece. When using S-Voice for voice commands and the bluetooth earpiece it has much less functionality. It is slow to react and often gets the words wrong. I do not have this problem when not using the bluetooth earpiece.
Is there an earpiece that works better?
I am using a Blueant Q2 but I don't use S-Voice because I hate how badly it works. I use Dragon instead.
I use the Motorola Elite Flip. With this earpiece you can download an app called MyMoto Speak. This app starts up when you turn on the earpiece. It will read back text messages. You can compose and send text messages with the app. It works very well. I've been using it for a couple years now.
I use a Jawbone, but I haven't really figured out how to use the voice command yet. Just got the phone recently. I know that it doesn't recognise my voice command past a certain point, so I have been unable to complete a voice dial.
I have S-Voice disabled, so I assume I'm using some sort of Google service. It's somewhat annoying because you can't just hit the BT button and say "Call 555-555-5555." It will tell you to say call name or number, then you have to say that name or number, and then it will tell you to say okay or cancel. It's accurate, but getting the instructions each time is annoying.
Me too, basically because you can then voice-dial even if your phone is locked with a pin (s-Voice will not). I don't mind its various confirmations of what you are doing, since it's very accurate (at least in my experience, so far). I use two different Plantronics headsets.
Good to know. That would make S-Voice pretty worthless. And yes, the other does seem pretty accurate. I've only had it mess up a couple of times.
I just got a Plantronics Voyager Legend. It's nice as I can verbally tell to answer or ignore calls (that it tells me who is calling if they are in my contact list as well) and not have to touch the phone.
It works reasonably well with S-voice, or you can use it with Google Now. I am still playing around with what I like best.
This thread makes me wonder how many headset features are controlled by the headset and how many by the phone firmware and apps. For example, I noticed that 4.3 changed the sound of the voice and other workings of handsfree operations using the same Plantronics headsets that I used before (with the built-in Android voice command firmware). Any info available on this? :confused:
I have the Plantronics legend, and I definitely hear the headset itself say "incoming call from" then the phone TTS voice say the contact name.
With 4.3, the default S Voice changed, and sounded completely different. I had to re-download the voices from the 'Samsung Apps' App to correct this.
If you clear out the default settings for S-Voice from within Task Manager --> Clear Defaults, it allows you to pick between Google search or S-voice when you long press the headset button.
EDIT: I noticed that Google search selection only lets you same a name or number - S-Voice lets you do more such as ask about weather, sports scores, etc.
