Which Kernel do I flash for the FI22 Build?
Once you decide on the ROM you want, follow the instructions for that ROM. Some of them have a one click Odin install that does everything and all you need is a pc with the kies drivers to do it with. Others use a CWM recovery to flash. Just make sure you read and follow the directions.
So basically I just flash a kernel that is compatible with the Custom ROM or..?
I am lost. Lol.
EDIT: NVM I figured it out. Thanks. :D
I chose the FL04 JB leak.
I tried CM10 and Pac-Man but 3G was a no go. I must have missed something flashing 'em.
Cool, That is what I am currently on. Only thing I needed to do was set the server settings for MMS messages to work right, but that is easy.
How do you fix mms anyway? I have yet to figure it out.
Okay have your MSL handy. From the Dialer dial ##3282# to get to the data menu. Choose edit and enter your MSL. Then you choose others. Your mmsc url needs to be http://mm.myboostmobile.com and then I changed my mmsc proxy to 68.28.31.1 (matching what stock was). mmsc proxy port I didn't need to change and is set to 80 (same as stock was) then back out.
Codegerm
