Which Phones Tether with Thrive?
humeston
I have to purchase a new phone as work is no longer paying for my iphone. Which Android phones tether with the Thrive?
Thanks!
None. Unless you connect by using your phone as a wifi hotspot. I use Easytether to tether my phone to my laptop and I asked them about the Thrive. It is something they are working on.
Just about any Android phone should work. If you're going to have work pay for it, then you should just have them add tethering to your bill. Otherwise you'll have to find a "workaround". Droid X with Liberty GB .09 rom tethers brilliantly with no fuss.
