Root Which recovery?
funkylogik
share the love peeps ;)
Cwm or twrp? (Or other?)
Is it a matter of preference or is one known to be better on the N7 (grouper)
Personally ive never used twrp, always cwm or cwm-based recovery on previous devices.
Cheers guys :-)
Ill maybe try it. Is it simple enough to work out compared to CWM/Philz? I like how Philz has the one tap option to wipe everything for flashing a rom. Not sure if philz is only for the s3 though.
Ive been in samsung-land for the last yr and a half lol. Itl be nice to learn something new :)
Multirom (dual booting?) seems like a good way for me to go mate.
I like using the latest bleeding edge rom but at the same time, my wifes gona be using it for youtube, facebook etc so stock would be best for her id guess.
Do any of the roms have Android Run Time yet or is that just not possible on this tab?
Cheers :)
Cheers :)
Not sure what Roms are trying art, I multiboot to use cyanogen as a general testbed and to occasionally try an image of Ubuntu Touch to see how it is progressing.
My wife uses the tablet as well, its nice to have a stable constant for her to use. Multiboot also requires no action from a cold boot, it will automatically boot your primary ROM with no user input.
Whatever ROM you are running when you install multirom becomes your primary, something to keep in mind if you want cyanogen as the default for example.
