I have two Samsung vibrants. One is running Atriarc and the other is running Trigger.
back on topic, VEGAn Tab is second to none. you can end your search there and be confident that you have made a good choice IMO.![]()
Stick with the Froyo based one for now I'm guessing?
Note:
WOOT purchasers, please read this before modding your device - xda-developers
roebeet saying to check the version before flashing, he's concerned that the woot ones might have a newer TnT version.
Wooter with VEGAn 5.1.1 and Clemsyn v7 = snappy tablet goodness.
Looking forward to what the stable (non-experimental) release of 2.3 will bring.
Now I just with the thing weren't so dang heavy. And maybe a kickstand like the Evo and Archos tablets would be nice....![]()
I'm not having issues with the updated stock ROM. What benefits are there to VEGAn or TNTLite?
Honestly, if you're happy with stock then you don't have to install a custom ROM. Installing a custom ROM (Vegan in my case) for me is preferable, because I want the google apps like the market, gtalk etc. I also have found it more stable and runs the apps that I use alot smoother than stock would.
Well, it was the lack of GTalk and the Market that finally pushed me. Installed TNT Lite 4.4 last night. In addition to GTalk and the Market, the interface is MUCH snappier.
How do I change my vote?![]()
Just loaded TnT-Lite 4.40 and all is extremely better!!!
OOP'S!!!
Just got the dreaded "process.android.acore" error. I had to wipe and clear then reinstall ROM using clockwork. Now to reinstall all of my apps.
Not sure what caused it.... low battery or installed app. Will wait and watch.
When you loaded your rom did you repartition your memory? Acore issues are caused by a corruption in the data usually pertaining to the contacts.apk. I have found that repartitioning your memory lessens the liklihood of corrupting your data again. You usually only have to do it once.
And am enjoying learning the aspects of Android since I did very little with my HERO phone, it now is getting more loaded apps.
