Root Which Rom are you using
Which Rom are you using currently
  • Velocity
    Votes: 16 47.1%
  • Stock
    Votes: 1 2.9%
  • Stormdroid
    Votes: 9 26.5%
  • Bionic Zer0
    Votes: 7 20.6%
  • Overstocked Beta
    Votes: 1 2.9%
  • Other
    Votes: 0 0.0%
  • Total voters
    34
db2u
I am just curious what the rooted Ally user base looks like at the beginning of 2010, almost 2 years after the phone was released.
Which ROM are you currently using?
1) Velocity
2) Stock
3) Stormdroid
4) Bionic Zer0
5) Overstocked Beta
6) Other (Frunisher, Byron Bare etc.)
Shaping up to be fairly even distribution between SD, Bionic and Velocity. Really didnt know what shape this would take, pretty cool to see the differences from just a few months ago.
stormdroid really crapped out on me...everytime I would turn my phone off it would take 30+mins to reboot. I did a reflash multiple times and made sure I wiped everything multiple times...so Bionic Zer0 for me!
Then you didn't wipe something. We've tested a lot, and that's never happened to us. also, NOTHING should take 30 minutes to boot. try flashing the patch? or the entire 1.2.1 ROM, and be sure to wipe everything.
have you heard of problems with the wifi and 3G?? everytime i leave the wifi on for a while it completely takes over the 3G on my ally and i have to reboot to get any 3G when I'm out of my house. anything that can fix that?? i've flashed 1.2.1 completely even though my phone still says it's 1.2...
Its weird that you mention that about Stormdroid because I get that same exact problem but with Bionic Zer0. I wonder why it does that
You guys with probs might want to start a new thread, generally get more views from people that might know the issue than at the bottom of a poll.
Yeah i did try everything you guys suggested...i wiped everything like 4x before flashing the 1.2.1 rom...i'm too busy with ICS on my nook color and some web dev to care about my phone right now haha
Currently running Velocity 1.2.2 Beta, so that's where I put my vote. However, shortly before I switched over, Bionic Zer0 was my main ROM. I like both enough that I'll probably keep nandroids of them around and switch between them every once in a while.
