chong67 Android Expert Jan 25, 2013 #1 I am looking for ROM for my new One S that is good and clean and remove of all the bloatware. Need your expert advice. Thanks.
razvan06 Android Enthusiast Jan 26, 2013 #2 I would suggest Cyanogenmod 10 - latest nightly will work just fine ! ...CM10.1 [Android 4.2.1] on the way ,so it's ok
chong67 Android Expert Jan 26, 2013 #3 Do you like the ViperRom? I am looking for a ROM that is close to stock but with all the bloatware removed.
agentc13 Daleks Über Alles Jan 27, 2013 #4 chong67 said: Do you like the ViperRom? I am looking for a ROM that is close to stock but with all the bloatware removed. Click to expand... Viper is good, as is TrickDroid. Make sure that you have a ROM compatible with your version (s3 or s4).
chong67 Android Expert Jan 28, 2013 #6 Yes, all the T-mobile use S4. Viper got alot of skin. Battery indicator can be changed. Which of the ROM has the ability to unclock when not in use? My favorite for my phone now is the MeanBean ROM. I m going w One S next week.
