Root Which ROM to choose - Viewpad 10s
sijoune
I recently got a Viewpad 10s with HoneyIce 3.2.7 on it.
Then i thought i should try another rom so i installed ViewCOMB 3.2 but it is a little laggy.
The guy i bought it from, told me that the most satble rom is Corvus5.
1- I would like some help to choose which rom to install.
I don't want to keep on trying diffirent roms, on and on. What is your experience?
2- Also i would like to know if roms for Advent Vega are compatible with my tablet, like VegaComb 3.2 or r8.
3- And finally the installation procedure is the same, like the one i followed for ViewComb, for every rom?
Thanks in advance.
Hi!
Just a little queation, just got my som a viewpad 10s but android 2.2 is so lagy on this tablet. The roms you are referring are note roms for viewpad 10s? Are they?
Best regards
Equal=ness
