Which root method is best if I do not intend to flash a rom with it right away? I just Odin'd back to stock and need to root to use Titanium Backup.
Thanks!
One click root 2.5.5. If you are looking to flash a rom then you will have to root using 3.0.0.6, and you can do this right on top of 2.5.5:
The big difference is that 3.0.0.6 coverts the file system over to EXT4 from RFS. Supposedly, it is faster than the stock Samsung setup.
heh
