H HtcStephen Lurker Jul 12, 2012 #1 How do i know witch sensation i have? I bought it from Cellular One, the box just says Htc Sensation but i see that there are several diff ones Steve
Tink-GB Member Jul 12, 2012 #2 Hi Depending on your software version go to Settings / About Phone / Phone Identity. The model will be detailed. Essentially you have a Sensation in the UK, in the US it's a Sensation 4G.. Even then each carrier personalises it too. Tink.
Rusty Android Expert Jul 18, 2012 #3 Pop the back off and see what it says under the battery. You can also check the CID to see what software type it should be (Unbranded, Voda, Orange, etc).
