Which US carrier for DHD?
jtai
Hi everyone,
I have an unlocked DHD and will be travelling to the US soon. Which carrier will the DHD work on and do they have a short term 3G data plan? I will only be there for a week and most likely on the move so wifi is not the best solution. Thanks all!
I use mine on T-Mobile. It will work on both T-Mobile and AT&T because it is a quad-band phone, so the best way to find out is check with either of them to see what their plans are. I'm on contract, so I don't know if they have short term plans.
Thanks for the replies. I'll have a look at at&t and tmobile. Don't suppose I can get 3G or faster speeds?
