Root which way do I go???
I need to root my wife's Inc 2 so she can use tethering, here is her build info, was wondering which way i should go, upgrade then downgrade, or just install the downgrade?
android version: 2.3.3
htc sense version: 2.1
software number: 3.02.605.1
pri version 1.92_002
prl version 52826
eri version: 5
i agree. if you have a revolutionary compatible hboot,run revolutionary before doing anything else!
if you have .98 or higher hboot,just downgrade,it doesnt mater wat build your one,you can upgrade after obtaining s-off.
bbery is correct,there is absolutely no reason to upgrade prior to downgrading :)
