I really hate to go off topic but can you really walk into a Best Buy and swap your black EVO for a white one? I'm really digging the white and would have gotten one if they were available on launch.
Are you sure they gave you a white Evo and not a white iPhone?![]()
If you are within 30 days you could sure.
So I got my white EVO yesterday. Had all kinds of problems setting up the account - the best buy guy was on the phone for about 2hrs.
While I am driving home I notice that 4G would just loop between "scanning" and "Connecting to Sprint". I checked coverage maps and drive to different areas and spend about 1.5 hrs on the pone with sprint all with no luck. The sprint folks are significantly less than useless.
So this afternoon I went back to Best buy to swap phone, I explain what the issue is, the scratch head and call sprint. after being on the phone for about 30mins the best buy guy decides to swap the phone. while this is going on another guys comes in to swap his black EVO because the screen was separating. All they have is white one so he decides to go for one of those. Now his Black EVO is connected to 4G and 2 other EVOs in the store are connected to 4G.
My phone is swapped and his is swapped, and neither can connect to the 4G network. Black phones sitting right next to the white one connect with out an issue, but 3 out of box white phone will not connect to 4G.
Anyone else with a white phone having issues? Sprint Tech support has no clue, and is really no help
BTW- my first white phone needed the latest OTA update. the second did not.
Update your PRL. I just posted to Sprint Forum thread here: HTC EVO 4G:4G not connecting?
It appears that a new PRL was just released and I am trying to figure out if this update fixes the 4G problems that many of us are seeing. I have had my phone for over a week now and I still have never connected to 4G and I have returned my original phone and received a 2nd phone, neither of which would connect to 4G.
The above linked thread is detailing what seems to be a problem with plenty of folks having cyclical "Scanning.. Connecting to Sprint... " issues.
Can someone with a white phone or is having problems connecting to 4G do a PRL update and report back?
But it shouldn't be possible because if you bought on launch you'd be out of luck since the white came AFTER 30 days since Jun 4th.
Updated PRL earlier, no change.
Contacted a Sprint rep on the phone, noted that Sprint / HTC are investigating the issue and are working on a fix. No ETA. Told me to call back in a week if there was no OTA update / change.
Yeah, I updated my PRL last night and checked the 4G connection outside my work. When I enabled 4G, it didn't show any signal at all (Used to get between 1-2 bars outside, by my work).
I have been watching the PRL closely since yesterday afternoon. While the PRL update always seems to report a "new" PRL update, the number doesn't change. Not until just this afternoon did the version number change to 60668.
Are you positive that you download 60668 last night?
Re-updated the PRL again, went outside, checked 4G...still no signal.
. Fortunately, bestbuy was able to order me a new unit and exchange it the next day. However, the unit still had the same issue. Now, I am on my 3rd one with the same issue.
I updated the prl. The "scanning loop" is still there.![]()
Do you get the "Scanning... Connecting to Sprint..." endless loop? My phone is able to see the 4G signal and I get the "4g is available notification" but it never connects.
If you are not seeing the 4G signal at all, I think you have a different issue than the one being discussed in the link I referenced above.
do you guys even read the thread before posting?????? do this, and your 4G will STOP "searching for connection"!!!
"I had the exact same problem. It has nothing to do with signal strength.
For some reason, the Wimax is set to disconnect after 10 seconds if idle time.
Idle time is defined by the number of seconds no traffic is passing to or from the internet.
When it disconnects, wimax will rescan and reconnect to the 4G network.
I found a fix for this, you will need your MSL code though to fix this so call Sprint and ask for it.
##DATA#
EDIT mode
Put in your MSL code.
Wimax
Change "Wimax_idle_sleep" from 10 to 300 seconds.
Click menu > commit changes.
Your phone will reboot and problem solved."
##DATA#
EDIT mode
Wimax
