Hi all,
Over the last week I've noticed that when using my Note II I occasionally get a very bright white line that flashes horizontally onto the screen. On Friday it happened on 6 separate occasions, and has already happened twice today. I turned the phone off for a while over the weekend to see if it just needed a reset but it's still happening.
It primarily happens when I wake the phone up - usually by passing my hand over the phone so it shows the time etc, although it has also happened when using the phone. The bright white line only occurs on the bottom half of the screen. Recently it has been in the exact same spot, very close to the bottom of the screen. It flashes onto the screen and disappears very quickly.
It's difficult to tell whether the screen itself has an issue, or whether the phone is flashing this onto the screen. It almost looks like a loose wire somewhere. Any ideas what the problem could be? Because it's an intermittent problem I'd have trouble demonstrating it for anyone. I'm gutted because I'd just figured out the battery issue and love this phone.
Cheers.
Cheers.
Is the power jack shorting out my phone?
