Help White screen after system update
SAGA PVT ENG S-OFF
HBOOT-6.98.2000 (PG8810000)
RADIO-3822.10.08.04_M
eMMC-boot
Android 2.3.3
Stock ROM
I just clicked to do system update when it offered me (didn't know it would soft brick it if it's just S-OFF (revolutionary), since I didn't do anything else).
I really searched everywhere to fix this but I am not really familiar with choosing the exact software (version) I need and don't wanna kill it even more.. :D I am still new do this so a step by step tut would be great. Thanks in advanced!
P.S. Only wiping cache and factory reset didn't work, of course... :rolleyes:
Never and I mean never try an ota with a modified phone, in your case hboot and recovery.
By the looks of it you ran revolutionary, then you flashed a eng hboot 0.98.2000
So is your phone branded or not? Try run the latest RUU to get back to stock, you will forfeit s-off and your custom recovery.
It's not branded. I've tried with installing official RUU Saga and installation took long process and seemed like it will succeed but at the end I got "bootloader version error"
Well, I guess you mostly learn on your mistakes but I really hope that this mistake won't cost me so much, since I have the phone for few days only.. Help ppl :D
@Morrigan69
Can you get to the HBoot screen? If so, can you select and use the recovery option?
If you can't access the HBoot screen, then follow Section 2 of FoX777's Guide.
You'll need to download and install adb and Fastboot to your PC. See here for the link to download the tools, as well as more about adb and Fastboot, how it's set it up and connects to your phone.
Solving your problem is going to be down to trial, error and a bit of luck. And even then you might not be successful.
Yeah, but I can't use the recovery option cuz I get a error and then it just reboots (had this problem also before but didn't have time to fix it lol). Since the phone is few days old only I'll try to go for warranty, and if that doesn't succeed I'll try that... But I really hope it will...
Hm, and I've already installed that tools but didn't find the right way to use it to fix my problem :/
