Root White Triangle with Yellow Exclamation Point
RJSH_1727
Member
Welcome to the Android Forums!
It sounds like it's trying to boot to recovery mode. If you hit the search button while the exclamation point is displayed it should take you to the recovery menu.
Hi, I came across this forum in my searches. I PERM-Rooted my myTouch 4G phone but I'm no longer able to boot into Recovery, via volume rocker and power button. My phone was rooted before and I never came across that problem. Two times now, I've seen that screen. I tried deleting a stock app via TB, and I saw that image with the Android guy in the middle. And just now, I tried to Flash a zip font I downloaded from XDA Forums, and I seen it again. I followed the Root Steps precisely. Do you know what could be causing this? Should I just unroot and start from scratch?
Thank you!
i have moved your question to the all things root section of myTouch 4G
i hope your question is quickly answered
i have as well pm'd you so that you can locate your thread
