Help White triangle
My android was left in direct sunlight for at least 30 minutes. Now there is a white triangle at the top, in the middle (no explanation Mark). This happened yesterday. It shut itself down but now I'm having problems with it. I can't get incoming calls, send text messages etc. 2 ppl told me that it should be okay in a few days but I'm not sure I trust that. Any advise?
Is it like this?
If that is the case, then the thread where that picture came from indicates you are roaming:
So sorry, i looked in the settings and in the Phone name it saysVs985 4G LTE. Hope that helps. im new at this.... I wish I knew how to post a picture
...I wish I knew how to post a picture
You've got a couple of options for doing this:
1. If it's a public link, you can click on the "picture icon" in the toolbar of the Reply Area (it looks like a rectangle with a sun and mountains in the background).
2. There's an "Upload a File" button directly below the Reply Area
3. You can just copy and paste an image into the Reply Area (that's what I did above).
Cheers!
