How many xe owners have a white one.? got mine from fleabay.
Just look under parts and Accessories for sensation xe .I paid 20 quid plus change for the body.original HTC part.
Means that it is taken out from the original used phone.
Thank you.
- uk-hitech
I emailed that seller several days ago, asking why they are sold as refurbished items.
So confused. Found this mean that they are new or not? I want to order one, didn't realise it was from Hong Kong, probably Wont get here by Xmas now either.
Are they really good quality, look new? Work fine, as there are a lot of connections etc on the cover.
Cheers
Did you order from the same bloke on eBay? UK-Hiteck?my cover arrived from hong kong within 4 days by UPS, not bad...
as for quality... it is a genuine HTC part,the numbers moulded on the plastic inside match. the machine marks in the aluminium are the same as on the case fitted to my phone,,,everything is the same, call quality, wifi, battery life.....
as it says on the advert, OEM......accept it
Oh so it's chipped already. Is this a fault of the cover or ou dropping it?
I've removed mine from a case now, because as you say, it's easy to buy and replace and in general I hate cases as they just add bulk. Currently use the HTC official slip case.
Hi,
Yep the case chipped when I went to plug the charger in. It hardly notices but still a bit annoyed. No drops so far. I've been looking for a cheap insurance policy for the phone but they're all so expensive at around
It shouldn't really chip though that easily should it? Was yours an officially bought white xe? Was this bought in a UK store?
Just buy another battery cover, black are cheap to.
Don't know about if yours is an official white XE, but my OEM one is really slippy, to hold in hand, and in case, compared to black one theres defo a difference. I have to be careful en if it in hand, anyone else?
Ah I see, how much did you pay if you don't mind me asking? Take it was just sim free. Maybe easier to buy here then buy a white back?
Buy a black cover prob cheap on flea bay.
I got mine through Phones4U![]()
lol
