Help Who is using live wall paper?
cwrig
My DX is supposed to arrive this week. The suspense is terrible.
From browsing the threads it appears to me that most folk end up with static wallpaper. Of course screen prints of the screen layouts makes it hard to tell if they are animated or not.
Does live wall paper kill the battery? Does live wall paper slow the device down noticably?
First of all, shame on you for getting a DX....lol jk
second, yes it kills your battery and your memory, they look cool, but if battery life is an issue, then no dont use it.
Mine runs them fine. The mario live killed it but I'm running a blue version of the droid eye. I'm at 70% and I already have 8 hours off charge. It doesn't seem to slow my phone or make it lag. Just give it a shot and see what works for you.
I used to use live wallpapers but i find it to drain my battery. Now i just use them to show off to iphone 4 users.
I have been testing between a live wallpaper and a static one. I haven't noticed much of a difference in battery life personally.
Ive been running a live one for 2 days and the battery life has been horrible. I dont know if thats the case but after reading this thread, I decided to go back to static and see if there is a difference. Ill post my findings tomorrow.
The live wallpapers are neat, I haven't used them because the wallpaper is pretty much hidden by all the other widgets/shortcuts. I assume while the screen is off, the live wall paper wouldn't affect battery life. Am I wrong?
The few times I have used a live wallpaper just to check them out didn't cause any slow down that I could see, but I haven't downloaded any of the high frame count ones.
I use a static one. But thats mainly because I haven't found one that I like. Only live ones I would ever use are simplistic ones. The one that was always advertised on the N1 for example.
