Help Who wrecked the build.prop in hybrid?
theperfectpunk
Who's the one editing the build.prop in the hybrid ROM, i just flashed it and found out the following issue
When USB is connected, the USB storage is not detected if tethering or USB Debugging is enabled.
it is the bug in droidmaxx v3 which is getting transmitted to roms based on it...
for that u have to disable the USB debugging and enable it again.
You have to do this again if u reboot.
