coolguy949
Here's my speed test history. The two large ones are Wifi. I wanted to make sure the app wasn't having issues. It's amazing to see the difference between 1 bar and 3 bars of Wifi. My 3G tests are dismal.
The real question here is, do you have any issues with your phone running on 3g? Can you load apps,download apps, browse web pages with out issue? If so then try the pdanet tether app and see what kind of performance you get and go from there.
Hmmm, I wonder if it could be the "data throttling" we saw a while back. I doubt it though. I remember my one speed restult on launch day, 10 mbps down and 5.52 up. I was amazed lol. Screenshot:
Its the last one as its sorted from newest to oldest.
Then things just got worse from there![]()
That is not possible. Not on 3g and not on 4g, you can not go faster then 10mbps on 4g and 3.1 mbps on 3g. It is a radio hardware cap.
Coolguy, please go to Speakeasy - Speed Test select San Francisco post the results.
I did, I get:
SF: 374 down, 160 up
LA: 662 down, 139 up (I'm in the LA area)
Did a trick that I found on a xda thread, the one where you hack the phone to work on VZ network. Worked great, got consistent speeds above 1mb at home where before i was getting only about 200-350kbps. but lost 3g after a day and a half, guess went over the roaming limit. But in the same thread there was another post about changing the SID, looks like most evos are set to Kansas city, changed mine to where i am, Providence, RI, and I am getting a bit better speeds. still hovers around the old speed some times, but more near or above 500kpbs most of the time, and sometimes jumps up to about 800kbs, only got that one time before at 2am, lol.
[6/16]*techknowfile's* - Hack the HTC EVO - 3G w/o Sprint EVDO coverage! - xda-developers
here is where i found the sid if anyone wants to try and not read the whole thread, it is somewhere in the middle. Sprints seems to be in the 4000-4999 range, just make sure you find the closest to you and that it is a sprint one.
The Roaming Zone-System ID (SID) List
You need your MSL to be able to do it, ##DATA#, Edit mode, enter MSL, go to advanced and scroll down to Home SID/NID, leave NID alone and just change SID, the first set of numbers. Hit menu, and commit changes. If it lists 4139 that means it was set to Kansas City. This is not the hack for VZ 3g, thats a whole other process, lol.
And just to add, been using sprint tv since the change back to sprint 3g with the SID fix, and it is running much better, little lag and no to little pixilation, much better than before at the same location.
terms of service said:Off-network Roaming: The primary use of your Device must be for domestic purposes within the Sprint-owned network. Domestic means use in the 50 United States and U.S. Territories (except Guam). Sprint reserves the right, without notice, to deny, terminate, modify, disconnect or suspend service if off-network usage in a month exceeds: (1) voice: 800 min. or a majority of minutes; or (2) data: 300 megabytes or a majority of kilobytes. The display on your device may not always be on and will not indicate whether you will incur roaming charges. You can monitor usage online through My Account. Roaming is not available with single-band phones, or to customers who reside or whose primary use is outside an area covered by the Nationwide Sprint Network. Sprint may limit or terminate service if you move outside of the Sprint owned-network.
i get about 1000-1400 but i'm on a different PRL. with Sprint's PRL, i was getting ~400
Take your phone to a service center, something is really wrong.I did, I get:
If you do this and you go above 300mb per month, sprint will kick you off. Period. Please read and understand your terms of service. What you are promoting can and will get a lot of people in some very serous problems. Please refrain from posting material that will cause people to get kicked from there carrier.
https://manage.sprintpcs.com/output/en_US/manage/MyPhoneandPlan/ChangePlans/popLegalTermsPrivacy.htm
Thats kbps, not mbps. That would translate to .3mbps and .6mbps
Are you doing the VZ thing? Got the same, but stopped working after a day and a half.
Yeah, I am not promoting the roaming one, but changing the SID is a different thing, does not have to do with using VZ network. It has improved coverage on the Sprint Network.
yes, but there's multiple PRL's and i tried quite a few before i found one that worked well with my location.
i use 40050 which is older.
i tried 40060, 30045, 40055, 01337, 31337, and 00001 before i realized 40050 was the best for me. some of the others would work, but then i'd go to a certain area and there would be no 3G, or some wouldn't work with 3G at all.
How long have you been using it? How much data have you used?
almost a month. i can't check data usage anymore because i just merged my account with my moms. i'll see if i can email her and get her account info and get back to you.
no info on changing the SID?
