Is there a way to change this?
I think sometimes if you are on the same carrier, the phones know how to piece the texts back together, my ex had verizon, and if she got long texts from other verizon members, it came up as one, but if I sent her a long text, it would come as two.
I can't verify that, though, just conjecture.
Actually I think that is true. My friend on ATT when I used to have it has sent me some lengthy texts and they were never broken up. But now that I moved to Sprint and he is still with ATT, they are now broken up.
AT&T and T-Mobile are GSM and do not have the 160 character limit that Sprint and Verizon have since they are CDMA. Verizon to Verizon will send over 160 without splitting it, Sprint to Sprint will not. The fun is when they get split and arrive out of order and confuse the person you sent it to.
I've noticed with the Evo, if they get split up, and the second half comes in before the first half, when the first half actually comes in, it shows up above the second half. It helps reading the message when it finally is all in, but it is confusing when you see new text, but it appears that its the same message. Now I caught it, it isn't so bad (doesn't happen much, maybe twice), but the first time I was thinking i was going crazy.AT&T and T-Mobile are GSM and do not have the 160 character limit that Sprint and Verizon have since they are CDMA. Verizon to Verizon will send over 160 without splitting it, Sprint to Sprint will not. The fun is when they get split and arrive out of order and confuse the person you sent it to.
