ramjet73
Android Expert
That's not a link, it's the password.umm i did.. there is a link for passwords. if you click it ... it goes to the main page of anthrax... like the link is broken
ramjet73
Here I thought you were referencing the band...I was about to say "Scott Ian's beard."
I just downloaded anthrax_universal_rls3.7.0.zip successfully.
It may be a user error.
I'm using Chrome on Windows 7.
ramjet73
Like I said, there must be something wrong with the browser you're using. I'm not seeing those duplicates in Chrome and I had no problem downloading the latest (3.7.0) Anthrax kernel.do you see what im talking about...
all right I figured it out.. But it still seems there are multiple files to chose from... 2 cdma+gsm folders and the when you click either one you will see there are to 3.7 folders.. I guess they are the same
Register at Anthrax Development.I'll be going through all this once my account gets approved. Out of curiosity, when did you register, and when did you get approval?
Are you using some kind of ad blocking or browser security software?im using chrome.. and when I use IE, or FireFox its the same.. I tried on my phone..... same thing...weird
**edit**.. they dont duplicate on my phone
i dont understand what could cause that to happen
Make a post in the "Forum/General Discussion/Welcome/Welcome New Users" thread right after you register and it will speed up the approval process.
ramjet73
I just checked that thread and your post is there and it was made 12 hours ago. It can take them a day or two to go through the pending posts so just be patient and I'm sure you will be approved.Actually, I did create an account last night, and I even posted in the welcome thread (which had over 2000 replies in it)
I can't seem to find the welcome thread now to confirm my post. I used the same username as I have here...so let me know if you see it![]()
It's actually pretty easy if you know where to look.
There's a tab for "Blogs" at the top of any page on that website. Click on that and then read the third entry and it will tell you how to get any of the Anthrax kernels for the Evo 3D/V that have been distributed from that site.
ramjet73
Are you using ROM or Kernel based MP Decision? after you install and setup in aroma, you have to ensure settings stuck in Kernel tuner
try xondemand governor
OS Monitor is a good app to use to check CPU usage since it will sort the tasks with the highest usage first.Anyone have any suggestions? How can I tell what's using the processor? Is that info readily available? Do I go into the on screen CPU use through developr options?
Anthrax is working OK for me now with regards to max CPU issues. The only thing I did differently was to choose ondemand in Aroma, and I think I may have lowered my max screen off freq. to the Anthrax recommended. Neither of those options should have made the difference, but that's all I got.
I've been running this for about a half hour, and it's very unstable. It's turned off a few times, and just generally acts funny. My phone is currently off right now. I gotta pull the battery again.
I am switching back to my latest Mobster/Buttered Toast NANDROID.
I wonder, could I be introducing a conflict if my max screen off setting in Kernel Tuner differs from what I selected during the Aroma install?
Anthrax is probably the best kernel of all time for the evo 3d. Chad got kanged and now he is suffering so he made his site private and password protected. Most of the kernels are based off of anthrax, like butteredtoast.
You need to get rid of any int.d scripts. Rename them by adding .bak to the filename. Also get rid of the post boot script. After doing this I haven't had a single random reboot.
Anthrax has never liked me for some reason. Just switched back to it from ButterToast and my phone just boot loops about a minute after booting to the lock screen. No OC or UC...going to wait it out to see if it settles down.
