why does facebook not update ppls profile pics on my phone and if i change mine it dont update that either. is there a setting or does the fb app just stink.
Just open the app and press the menu button, then select settings. If you scroll down their should be an option that says sync contacts, click it and it allows you to customize who you want to sync.
Mine stopped updating somewhere along the line. Never understood why.
Perhaps going into application settings and selecting clear cache, or going into a program like Titanium Backup and wipe data will fix. Never tried doing that because I found another way.
Downloaded "SyncMyPics" from the market and that takes care of the problem. It copies the facebook photos to your contacts.
