computerpro3
Member
I'm coming from windows mobile here so I'm not sure if this is an Android thing or the Incredible specifically, but the bluetooth implementation absolutely sucks.
I'm using the phone with the Plantronics 975, which is an absolutely fantastic earpiece. The problem is that it NEVER automatically reconnects to the headset after moving out of range and then back in. I've also verified this with an old motorola headset, so the phone is the problem.
With my Touch Pro 2, I could walk outside to my car to get something with the earpiece still in my ear, and the phone would disconnect and then automatically reconnect when I get back inside.
Not only does the Incredible not do this, but when I come back in, even after pressing the button on the bluetooth headset (which I didn't have to do on WinMo) it just says "paired but not connected" in bluetooth settings.
In order to get the phone to reconnect with the headset, I have to turn bluetooth off, back on, go into wifi settings and click "connect" EVERY SINGLE TIME I go out of range and back in range.
Coupled with the infamous lack of touchless voice dialing, I am seriously dissapointed in Android's implementation of bluetooth, and don't understand how Google can put out a phone that sucks so bad as a phone - especially when in many states such as mine, a bluetooth headset is the ONLY legal way to use your phone when you drive.
Any ideas how to fix this annoying problem or am I just stuck with it?
