When I'm at home, sometimes it drains every 40 mins. Other times it drains every hour or every hour and a half. I don't use the phone. It's just on idle.
The battery is constantly draining while unplugged no matter what.
Now, things that can affect battery when idle:
Signal strength (ota or wifi)
App synchronization
Background processes.
Undesired wakelocks (due to misbehaving apps)
The best thing to do is this. Download the app, Gsam Battery Monitor. User Guide for Gsam.
Fully charge the device, unplug, and let it sit idle, if possible.
After several hours, open Gsam and monitor what is using the battery.
You can even post screenshots here if desired to decipher what's going on.
Doesn't matter if you use the phone or not... if your phone is sat in an area with weak or no signal the battery will plummet (unless flight mode is enabled)
How long does your battery typically last?
Edit: sorry, I got booted off the internet for a bit....are you saying, your battery lasts 40 minutes or sometimes an hour before going to zero?
Also I'm having another problem. I restarted my phone while it was charging and the battery dropped from 100 to 99% when it restarted. What could cause this?
