Help Why does my Photon show my battery status in intervals of 10%?
I have downloaded many different battery widgets but they all count the battery of my phone in intervals of 10. My Lg Optimus M shows me battery status in intervals of 1 -- the Photon will not do that.
Any tips?
Any tips?
Been mentioned before, but there are certain battery apps that don't account for the 1% increment. Something built into Motorola phones. Here are some battery indicator apps that have proven to show the 1% increments:
https://market.android.com/details?id=ch.blinkenlights.battery
https://market.android.com/details?id=fr.depoortere.android.CircleBatteryWidget
I'm sure there are others as well, but those two seem to be the most popular.
Thanks! Any chance there is a different version of TEAM Battery bar that also goes 1% at a time?
https://market.android.com/details?...=W251bGwsMSwxLDEsImNvbS5wdnkuYmF0dGVyeWJhciJd
Oh, wow, that's cool. I used to use something similar on my Windows Mobile phones before. But, not sure if there is something similar to it that works with Motorola showing 1% increments because it's the first I've seen this particular app.
Have you tried emailing the developer to see if they can make it work to show 1% increments for Motorola Phones?
If you're rooted and your bootloader is unlocked the ROCKO rom on XDA developers shows 1% battery increments by default. It also has Beats audio built in, alows me to overclock my CPU to 1.3Mhz, oh... and I am 28 hours off the charger and my battery is at 69% as I type this!!! Just do it people... the Photon is a beast if you'll only let her out of the cage!!!
I plan on porting to Boost Mobile, so I don't want to mess with anything.
