iLLMATICxKiNG
Like I want to use it while it's charging but it's unresponsive and not accurate at all.
It's the charger that came with the phone and it's hooked right up to the outlet directly. At first it was hooked up with a different charger and had it hooked up to a surge protector then I read on here that can cause problems so I used the stock one directly into the wall and it's still doing it.
It may actually be a defective phone. does yours get hot?
I am having the same issue on this latest refurb and the phone is too hot to touch as well.
I did not have the issue on previous skyrockets
The people at Samsung recommended a factory reset. Before I do that I need to get an SD card but does anyone know if that will even fix this problem?
There is no way to know for sure.
Have you tried another cable and or charger. it so far appears that only my samsung charger + harmony remote cable cause the issue...my car charger and another that i have do not.
I am going to try samsung charger and cable tonight
I have tried one other one and it did it so i went back to the one provided with the phone.
I have this same issue with my google pixel 3. I checked it and it was the charger that was malfunctioning while the cable was fine. I used a different charger and it charged normally.Like I want to use it while it's charging but it's unresponsive and not accurate at all.
