My GS3 cellphone was facing a big issue that the handset gets overheating easily since last month. Not sure whether this problem is causing by the Processor, battery, software or other hardwares of the device…Then I troubleshooted the GS3 myself, and my first idea was to replace a battery so I take out a MPJ 6000mah replacement battery for S3 which was fully charged and swap it to see if it is the oem battery should be blamed. I don’t know whether I am lucky or not----the result is…yes, I need to replace battery….the good thing is i don’t need to continue to troubleshoot my phone…
I already know cable, battery or charger malfunction, Low hard disk space and more usage may cause the problem… But still, wander what are the other possible issues might cause Samsung S3 overheating??
