Random Kiwi
Hi All
Recently my alarm just randomly started telling me the time when I move the phone to slide the Snooze/Off slider...it keeps quiet just doing the alarm tone until I touch the phone, then bam, robotic voice says "the time is zero six forty five" etc
It's super annoying as I rise earlier than my wife so can't quickly and quietly switch the alarm off without it doing this...didn't change any settings, deleted and re-added the alarm, still there...any clues?
It also started doing it with calls this morning, starts ringing, then pipes in with "you have a call from private number"
Also, just added a 32Gb SD card for more room for music/photos, manual only really shows how to insert card and format if required (not required), but nothing about how the phone uses the card...can I just continue to Drag and Drop my music into the Music folder and it knows to put onto the SD card if the phone memory is full? And does the music player know to look for things stored there as well as on the phone? Is it best to only use Keis to put music onto the phone as it'll then know where to store it and how to find it?
Same with Apps? If I download straight to phone, will they just start storing on the SD card when the phone memory is full?
Cheers for your time, and apologies if this is a bit ******ed, I'm very new to the smart phone world and none too tech-savvy...thanks!
