Help why is my ringer.self muting?
Stevessvt
2 timetimes now my ringer has muted itself. But all the volumes are maxes out and nothing is set on mute. I have sound manager on it, but it has nothing to do with the ringer, just notifications. What's going on?
Moved to troubleshooting. Have you checked the menu options,
Menu/Settings/Sounds/DoubleTaptoSilence
Menu/Settings/Sounds/SmartProfile:FaceDowntoVibrate
GMB
GMB
Thanks for moving it, I hadnt looked, but I just did and both are unchecked. Every other sound works fine, and under both sound in settings, and the app sound manager all the volume sliders are pegged, when I use the rocker switch it is full and makes the beep when you move the slider up or down. The only way I got the volume to return was to use the rocker to slide it all the way to off/vibrate only, and move it all the loudest again. Something to do with either the app Sound Manager, or my other sound app, Volume Control I believe
