Why is Sprint Navigation always on even using advanced task killer
andyacecandy
I have my GPS locations turned off. I use advanced task killer to kill all running apps... then I check my phone, and it Sprint Navigation is on every single time....
If you download the app Autostarts it shows what triggers start certain apps. For some reason when you use your messaging app it will start sprint nav. No idea why. If you root your phone you can disable it so it doesnt start that everytime. Autostarts will still show you that without a root.
